configure flow-redirect add nexthop
configure flow-redirect flow_redirect_name add nexthop ipaddress priority number
Description
Adds a nexthop for the named flow redirection policy.
Syntax Description
flow_redirect_name Specifies the name of the flow redirection policy.
ipaddress Specifies the IPv4 or IPv6 address of a new nexthop.
number Specifies the priority value for the nexthop.
Default
N/A.
Usage Guidelines
Use this command to add a new nexthop for the named flow redirection policy. You can specify an IPv4 address or an IPv6 unicast IP address (IPv6 multicast addresses are not supported). After you enter an IP address, the redirection policy only accepts addresses from the same family as the first address specified. For example, if the first IP address added is an IPv6 unicast address, you cannot add an IPv4 address to the policy.
The priority value can range from a low of 1 to a high of 4096. The nexthop with the highest priority among multiple ones is preferred as the working nexthop. When each added nexthop has the same priority, the first one configured is preferred.
The following example adds a nexthop 10.1.1.1 for the flow redirection policy flow10 with a priority of 100:
configure flow-redirect flow10 add nexthop 10.1.1.1 priority 100.
Support for IPv6 flow-redirection policies was added in ExtremeXOS 12.7.
The maximum number of flow redirects was increased to 4096 in ExtremeXOS 16.1.
Platform Availability
This command is available for IPv4 and IPv6 flow-redirection policies on the platforms listed for the Policy Based Routing feature in the Switch Engine v33.1.1 Licensing Guide document.
